Hi there 2pack, just checking if you know why this is happening...
Its strange issue.
trying to run 3800mhz @ any timings with infinity fabric @ 1900
causes the system to boot up with a error code 07 cpu error...
the memory though will run XMP no problem @ 4000mhz with infinity fabric at 1900
and this is at crazy timings 16.16.16.36 @1.45v
and boots up no problem at any other frequency's or timings 3200/3400/3600/3700/3900/4000
work but 3800 wont,
its not a fabric issue as i have tested the fabric at 3800 mem with 1800 or 1700 still 07 error on motherboard....
this is with a 5950x/GODLIKE x570...
and one other question please, do you know what voltage controls or makes the infinity fabric more stable
computer runs fine but i get quite a few whea errors with infinity fabric @ 1800/1900 no issues and no (whea errors) but 2000 works but gives me those and i have no idea how much voltage i should push or where to get more stability to be able to remove those....
Its strange issue.
work but 3800 wont,
