Man of Honour
- 13 Nov 2009
- Northampton
I was moving some files around over the network to my FreeNAS server yesterday and noticed slower than normal transfers.
After running Iperf between the FreeNAS Server and my PC I'm seeing 500-600Mbits/sec transfer rates. Along with ~56% NIC Usage on the windows PC in Task manager.
If I run the same iperf command from two seperate windows machines they will push around 450Mbit/sec to the server each, so I assume it is safe to say that the FreeNAS server is more than capable of fully utilizing its gigabit connection. I've tried using jumbo frames which makes no difference, and the windows machine are using onboard Realtek NICs and the FreeNAS server has a Intel PRO/1000 GT.
Is this simply a case of the Realtek NICs being crap?
