Question in thread title, in my situation the blow out is near the back, and if im working this out right im getting about 18 MPG. Car is a toyota celica GT.
But why does that matter, i would have thought the lambada (im probably not spelling that right) sensor would take care of it. Its after the centre box/cat before the back box, so its just missing out on the back box.
The change in back pressure would cause the AFR (air/fuel regulator(s) ) to behave differently. Usually this means they run rich, so you use more fuel to cover the same amount of distance.
Im just working this out, well trying to, I think its worse than 18MPG. I've done 59 miles since last filling up, and that was £15 worth (17 litres say?) and its nearly an empty tank again. Isn't that more like 14MPG?
The leak will suck air in once the engine is loaded up with a decent gas speed in the exhaust.
This then leans the reading the lambda sees, so to compensate the engine fuelling increases. The lambda then sees around stoich BUT the engine is actually overfuelling by a significant amount hence effecting MPG.
Thats only really gonna happen if the leak is upstream of the lambda sensor though.
