- 14 Apr 2004
- UK
As per thread title,
I've constantly been having problems, I just really need to get this one out of the way.
Basically I installed my Zalman 9700 delivered yesterday, I installed it fired it up and I was chuffed to bits when I looked at the temps in Bios. 30 degrees idle as opposed to me 55 idle. I get into windows and I stressed it with tat for ages. I got to 50 degrees maximum. It then cooled down to 34 idle which was acceptable. Last night it started become about 48 idle. How on earth did it get so high?
I resat the heatsink and applied thermal as pictured:
A very thin layer. I booted up the pc and went into bios it was at stupidly high temp 70 degrees!
I then rebooted and it settled to 50, how does that work?
I've ran orthos and similar apps and I'm now at 46 degrees idle & at 70 load.
I genuinely can't get my head around this, my heatsink is secure it can with some pressure move side to side but seen as It has 1 set of intel S shaped clips on, it seems feasable.
I'm really frustrated and I really want to overcome this problem as it's a huge nightmare.
