It would be practically impossible to ensure good contact between 1200 pairs of pads
So how does having a bed of pins (LGA) make it easier?
What if the pads were raised on one or both ends? Slightly concaved.
Maybe make them springy to ensure good contact?What if the pads were raised on one or both ends? Slightly concaved.
I guess a non chip analogy would be when the legs on a chair aren't quite the same length and only 3 of the 4 are in contact with the ground causing it to rock
We could always go back to cartridge CPUs.
https://en.wikipedia.org/wiki/Slot_1
ThisI think you probably mean convex, but the same issue would apply, if any of them protruded a little more/less than the others then the chip would sit on those longer bumps and the shorter ones wouldn't make contact.
My Celeron 300A clocked past 450mhz (this is "overclockers" afterall!) was £63.64 iirc nearly a quarter of a century ago and still felt like you were getting a proper piece of kitYep. My Pii 450 was £600 nearly a quarter of a century ago but at least it felt like you were getting a proper piece of kit![]()
My Celeron 300A clocked past 450mhz (this is "overclockers" afterall!) was £63.64 iirc nearly a quarter of a century ago and still felt like you were getting a proper piece of kit![]()
