coming from 60+ fps gaming to 30 fps the difference is night and day; it's horrible playing at 30 fps in my opinion, even with a controller a few metres back from the TV.
http://en.wikipedia.org/wiki/Interlaced_video said:Interlaced video is a technique for doubling the perceived frame rate of a video display without consuming extra bandwidth. The interlaced signal contains two fields of a video frame captured at two different times. This enhances motion perception to the viewer, and reduces flicker by taking advantage of the phi phenomenon effect.
, the specs are a g3258 and a 270 x so I expected to match at least the Xbox one for visuals and framerate . The g3258 is a very capable CPU still but hasn't got that oomph to lock 60fps at any setting So due to the drops I created a custom refresh rate @ 30hz and enabled vsync . And maxed out the settings to a point where I noticed drops below 30fps the. Pulled bk slightly . Runs solid At 30fps no drops at a mix of high/veryhigh settings @ 1080 , certainly looks better than the Xbox one version . I could only play at this refresh rate a decent distance away from the TV and with a controller . As up close even locked at 30fps it dosnt feel constant even though the fps counter is saying it's solid . But on the sofa I barley notice .doesn't the tv go to 30hz when connected to a console?
