I've been having a bit of a fiddle with the voltage settings, specifically vcore, to see how low I can take the vcore on my i5 750 at stock speeds (spec in sig). I've noticed that when the vcore is set to auto, it goes all the way down to 0.848V when idle and up to 1.23V ish at load. If I set the vcore manually (currently down to 1.06875V) then the idle voltage never goes below 1.024V. I know its not a massive difference but how come auto can take it lower than a manual setting?
