Why does Computer Properties show my stock CPU speed and not the overclocked speed?
Caporegime
29 Jul 2011
In acme's chair.
On my rig in computer properties it says:
"Intel Core i5 2500K 3.3GHz @ 3.3GHz"
Instead of:
"Intel Core i5 2500K 3.3GHz @ 4.7GHz"
Why is this?
On my old pentium 4 rig with an overclock (windows 7 still) the properties page said:
"Intel Pentium 4 2.8GHz @ 3.2GHz"
So why is this new CPU different? is it because of turbo-boost?
I have no idea honestly. With my 2600K @ 4.4ghz, initially it said @ 5.8ghz, but then after a few Windows updates it dropped to 4.3ghz. CPU-Z still says 4.4ghz though. So I just assumed it could be Windows not reading SB/IB speeds properly.
oh windows, you so silly... Overclocking from 4.2GHz to 4.7GHz only increased my experience index score from 7.6 to 7.7 out of 7.9 lol xD (dont worry, i disregard the exp index but i re-ran it out of curiosity...) I want to OC my ram to stop any bottlenecking, but my motherboard is getting a #45 error when i try...
if you've done it right it should only go to the overclocked speed when the pc is being pushed, or benchmarked; theres no point running flat out if its sitting idle on the desktop.
Mine does the same nothing to worry about.
ok :)
It is still quite annoying though... The Computer properties is a convenient place to go when people ask for your basic specs (if they are there with you and you want to show them something not too complicated) and it doesn't even show the right clock speed lol
I noticed mine is asways 100Mhz lower than the OC speed, unless at stock.
A little annoying when you spend the time and effort to achieve that extra .1 GHz. :)
ok :)
Just download Speccy and Cpu-z! Speccy will show the full spec of your machine and Cpu-z your clock speeds ect! Job done.
Mine is the same, reports stock clocks, i'm sure i've read about a fix for it, not 100% sure:confused:
