Why does engine braking work better in the wet?
26 Apr 2008
Bristol, Old Blighty
Or is it just me? There's a particular downhill road I drive down pretty much every day. When it's dry, I have to apply the brakes to stop myself speeding up. When the weather is damp, I don't. Why does that happen? :p
When it's wet the water on the road adds extra friction.
It reduces friction between the tyre and road surface, though a significant depth of water would increase rolling resistance. On an averagely "wet" road at lowish speeds I wouldn't have thought it would make much difference.
More likely that the cool, damp air is actually increasing engine braking slightly. Moist, dense air would increase the pressure drop across a closed throttle, increasing pumping losses.
Is it because you're driving slower as its wet? ;)
I'm with this guy, you're must be driving slower but when it's wet there's extra noise so probably makes if feels/sound like you're going as fast.
Friction is reduced but that wouldn't affect this as it won't be breaking traction. I reckon its just different gas properties offering more resistance to the engine, and the water on the road giving a small extra resistance.
Actually I think it's a bit of everything above.
Already decreased speed due to wet conditions
thicker cooler air affecting engine closed throttle
rolling resistance to tyres increased by stending water.
Is that to say you have never noticed a change in engine charateristics between a scorching hot day and a cool one?
Sure, certainly recently noticed it run nicer in the cool evening than the scorching midday sun. That doesn't really have anything to do with engine braking though, in which I can't say I've noticed any difference. Frankly I can't see why it would make a difference anyway given that engine braking is caused by the lack of air in the manifold.
I'm not driving slower. I always check my speed at the top of the hill, and it's always 29-31 (indicated). In dry conditions this creeps up to about 35 by the time I reach the bottom unless I apply the brakes. In wet conditions, it goes up to maybe 32 if I don't apply brakes.
It's a fairly straight bit of wide road so there's no reason to drive slowly on account of rain.
so when you go through a massive puddle on the motorway, the car slows down dramatically... is that becuase there is no frictions?
