Why does my Computer keeps falling asleep on games?
21 Sep 2012
ON MY OLD PC (Current), whilst I get my new one sorted out, I've had this ongoing problem which one day just started happening out of nowhere and its so annoying its unbelievable.
More than half of the games I go on after about 10 mins my computer says, monitor going to sleep, then I have to restart the whole computer.
I have tried many solutions such as,
Changing my computers power plan.
Turning both sleep and hypernate modes to never.
Uninstalling and then reinstalling the display adapter in device manager.
Making sure everything is up to date. ie checking for updates.
Lowering the graphics settings even when they would run fine otherwise.
Could it be anything to do with memory and my OS? Im on Windows 7 32 and 64 bit, with like 4600mb available virtual memory if thats the same as ram, and on computer properties it says installed ram is 3gb.
Any help would be of great assistance, thanks.
Might it be the PSU?
Can you list your full specs?
And have you ran any virus checks?
Can you recall what software you may have installed prior to these events.
