[TW]Fox said:Crappy small displacement 4 cylinder engine?
Wryel said:Thanks guys, I'll have a look. The exaust is new and the noise definitely is from the engine.
Crappy 406 1.8 btw.
Crappy 406 1.8 btw.
Which obviously sounds like its got a briggs & stratton under the bonnet[TW]Fox said:See that shouldn't sound lawnmower like - I thought it was a 1.2 Corsa or something.
Duggan said:Have you checked you spark plug and HD leads. It could be that the car is only firing on three cyclinders. I am having a problem with my car thats sound sort of the same but mine turned out to be my head gasketi did all the trouble shooting first thou. I would check the sparks,hd leads there cheap to replace and really need to be done every once in a while so its a good place to start. Good luck
malc30 said:You say you have had a recent clutch change. Did they replace the thrust bearing.
Put your hand on top of your gear stick as you accelerate and feel for a slight rattle that goes with the noise.
Or Exhaust, Put foot over tailpipe. Car should splutter and muffle right down.
Or pipe off airbox Lift bonnet look.
Or No Oil. Check level.
Also check the shroud around the gearstick assembly. Make sure it has been refitted properly.
