I don't seem to be getting a very high score in Firestrike.
http://www.3dmark.com/3dm/1749565?
Is this down to my CPU?
Thanks
Thanks
Thanks![]()
This is what a 7990 quad fire setup scores overclocked, your scores both look there or thereabouts to me chaps, unless im missing something.
7990x2@1200/1700
http://www.3dmark.com/3dm/1439194?
3. 19763. GFX Score 34586. 7990. Water cooled cooled. Physics Score 16440 CPU 3930K @ 4.75 Water cooled - ToxicTBag - Link
This was pulled from Kaap's excellent firestrike extreme thread.
13610 I score the other score is 19763.
The graphics scores are closer...
Its your combined score, that's dragging your overall score downwards loads. Your GPU score is fine however (sorta) so the problem lies with your CPU.
Go back to stock and try again. The CPU score isn't too far off where it should be mind (physics score)
7990x2@1200/1700
Thanks![]()
I have just run this on my GTX 690s with a big overclock for them 1210/1800 (boosting to 1254)
http://www.3dmark.com/fs/1230511
If you check the graphics score I am still nearly 4000 behind your 7990s.
If you really want to check the graphics power of your cards, you should give the Heaven 4 bench a go. This will really show what your cards can do and is more relevant to games than some of the other benches.
Edit just checked and my combined score goes down when I run 4 GPUs too, when I run a couple of 290Xs my combined score is well over 8000
