Why does my internet randomly disconnect?
12 Dec 2005
Hello guys.
This is really starting to get on my nervs, my internet will just randomly disconnect, and i will have to restart my PC to get it to connect again.
Im on BT Broadband
My Modem is a : BT Voyager 205 ADSL Router.
Any help on stop this frmo happening??
Thanks
Not without at least some stats - attenuation/SNR margin.
http://www.kitz.co.uk/adsl/frogstats.htm said:
BT Voyager 205
Telnet to the router IP address
or click --> 192.168.1.1
Logon with "admin" and your password (default = admin).
at the $ prompt type: get dsl params
You are looking for:-
Local Line Atten(dB) & Local SNR Margin(dB)
denic2k6 said:
Hello guys.
Im on BT Broadband
Thanks
If you have a router rather than a modem it is a bit strange to have to restart your PC as that won't usually have any effect on the link between your router and the internet.
Are you sure the router is disconecting? You should be able to tell from the status lights, or the status page on the router if it is actually dropping the connection.
Sounds more like a PC issue than an internet issue in the absence of more details.
