Why does my internet speed fluctuate so much?
Status
Not open for further replies.
Call your ISP and work to resolve these problems with them. I had a similar problem with Virgin Media, after a couple calls I had my bill halved for the remainder of my contract or until the contention ratio improved such that my internet speed fell in line with the speeds advertised. The contention ratio never improves with VM, so now I'm with Plusnet.
Anyway, aside from that you say you're on WiFi? You could purchase better networking equipment? I've got an Asus RT-AC87U which is great for the WiFi and TP-Link AV1200 Gigabit powerline hubs for wired connections to my TV, PC and NAS, my network rocks now.
Is that your router reporting the connection stats or are you running speed tests? You'd be better off getting the sync speeds and making sure it's not that first.
Also, probably better if this was in the correct subforum :)
Status
