Why does my memory appear as Single Channel?
24 Apr 2007
When its this stuff?
https://www.overclockers.co.uk/showproduct.php?prodid=MY-054-TG
Am I been a Noob?
Do you have it in the correct slots for dual channel, usually slots 2 and 4. Also in bios enable xmp to get the ram running at its correct speed.
the slots are counted towards the cpu on that board, the furthest being slot 1 and the closest being slot 4. The ram should be installed in slots 1 and 3 if you only have two sticks.
The xmp setting is still rather low, are there multiple xmp profiles in bios? Your timings should read 10-12-12-31, 1200mhz ddr.
Thanks for your help everyone.
EZ Tune now give me some crazy figures which I don't think I'm going to go anywhere near, but know that my configuration is right.
Now for the next 16GB :-)
