Why Does Ryzen Master cause my Monitor to flicker??
15 Oct 2007
Bedfordshire, UK.
So i have noticed when i run Ryzen Master i get a flickering effect at the very top of my display, when i terminate Ryzen Master the flickering magically stops.....
Any idea why the heck this happens??
Do you have Rivatuner open with msi afterburner? I only ever encountered a similar issue when rivatuner was polling the app and running a silly frame rate causing the flicker.
Are you using g-sync?
If so, use the nVidia control panel, add a profile for this application, set the refresh technology for fixed refresh instead of adaptive - then tell us if it stops.
