Why does the CPU run so slow
30 Apr 2003
jarrow
My girlfriend has a Fujitsu Siemens Amilo M1451G Laptop, ive just check the cpu speed and its only running between 700-800mhz. Ive checked the bios and it doesnt have the option to change the fsb or mulitplyer. When i checked the stats using Everest i noticed that it went from 800mhz upto 1733mhz before settling at what is in the report. Also the core voltage fluctuated with the increase of the cpu speed before dropping to what is in the report below. I would apprciate it if some of you could check the stats below and let me no if there is a problem with the laptop. Why would the muliplyer drop to 6 and why would the core voltage drop ???
CPU Properties:
CPU Type Mobile Intel Pentium M 740
CPU Alias Dothan
CPU Stepping C0
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) M processor 1.73GHz
CPUID Revision 000006D8h
Core Voltage 0.796 V
CPU Speed:
CPU Clock 702.25 MHz (original: 1733 MHz)
CPU Multiplier 6.0x
CPU FSB 117.04 MHz (original: 133 MHz)
Memory Bus 175.56 MHz
CPU Cache:
L1 Code Cache 32 KB
L1 Data Cache 32 KB
L2 Cache 2 MB (On-Die, ATC, Full-Speed)
Motherboard Properties:
Motherboard ID 63-0100-000001-00101111-093005-Alviso$M50EA000_BIOS DATE: 09/30/05 18:43:59 VER: 08.00.11
Motherboard Name Unknown
Chipset Properties:
Motherboard Chipset Intel Alviso i915PM
Memory Timings 3-3-3-8 (CL-RCD-RP-RAS)
SPD Memory Modules:
DIMM1: Hyundai HYMP532S64P6-E3 256 MB DDR2-400 DDR2 SDRAM (5.0-3-3-8 @ 200 MHz) (4.0-3-3-8 @ 200 MHz) (3.0-3-3-8 @ 200 MHz)
DIMM3: Hyundai HYMP532S64P6-E3 256 MB DDR2-400 DDR2 SDRAM (5.0-3-3-8 @ 200 MHz) (4.0-3-3-8 @ 200 MHz) (3.0-3-3-8 @ 200 MHz)
BIOS Properties:
System BIOS Date 09/30/05
Video BIOS Date 05/06/08
DMI BIOS Version 1.04C
Graphics Processor Properties:
Video Adapter ATI Mobility Radeon X300 (M22)
GPU Code Name M22 (PCI Express x16 1002 / 5460, Rev 00)
GPU Clock 105 MHz (original: 300 MHz)
Memory Clock 122 MHz (original: 230 MHz)
CPU Properties:
CPU Type Mobile Intel Pentium M 740, 1733 MHz (13 x 133)
CPU Alias Dothan
CPU Stepping C0
Instruction Set x86, MMX, SSE, SSE2
Original Clock 1733 MHz
L1 Code Cache 32 KB
L1 Data Cache 32 KB
CPU Physical Info:
Package Type 479 Ball uFCBGA / 478 Pin uFCPGA
Transistors 140 million
Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Die Size 88 mm2
Core Voltage 0.988 - 1.308 V
I/O Voltage 0.988 - 1.308 V
Typical Power 3.0 - 21.0 W (depending on clock speed)
Maximum Power 3.3 - 28.1 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 0 %
Much apprciated in advance - the laptop is around 9mths old
the Mobile Intel Pentium M 740 has Support for Intel Mobile Voltage Positioning (Intel® MVP IV) syste, which means that the CPU lowers the voltage based on processor activity to lower thermal design power enabling smaller laptops.
So the less you use the CPU the less speed it goes to saves power + heat, once you start to do something it kicks back in and goes full speed.
Much like AMD's Cool N' Quite system
EDIT: your link is broked.
http://www.intel.com/products/processor/pentiumm/index.htm
Wow that was a super fast reply, thanks for that. I thought there were serious problems with it. Sorry about the link as i just cut and pasted the info from the report to the post - i did think it would attempt to take you to the links page.
Thanks again for the quick response
no problem, the link you gavce just landed me at Intel: Page Cannot Be found. I had the correct link bookmarked funny enough
