Why does winamp use so many CPU cycles? Is there a more CPU friendly mp3 player?
18 Oct 2002
I'm using winamp 5.03a however, having just called task manager up i've noticed that it uses between 20-25% of the CPU cycles (P4 [email protected]). I've got into the habit of playing tiger woods 2006 with MP3s on via winamp and had noticed it was chugging a bit and therefore i am considering ditching winamp and using something that doesn't hog nearly 1/4 of my CPU time.
Any suggestions?
Spudgun
PS oh, is this amount of CPU usage for winamp normal?
Something wrong there. Task manager shows my active Winamp5 as using a constant 0% of CPU time. Try a reinstall of the newest version?
Seems strange, I use iTunes and it doesn't seem to use any measurable CPU time when just playing mp3's and only upto about 5% when loading in a new track from disk.
Jokester
if you just want an mp3 player and not interested in the visual stuff you get with winamp, try foobar2000! great lightweight player.
Or try soritong, a great little player that can be used as a bar on the top of your screen. Though like the posts above even with songs playing winamp rarely stray's above 0% for me too.
