Why don't my sig work no more???
11 Jul 2006
The Isle of Wight, UK
Can someone give me the/a proper link? I used to use the 'paulgraydon' one but it doesn't seem to work any more!
I just want my stats back....
The links Croni posted are to null's sig generator, which is pretty good. If you just want Garp's one back:
Garp said:
Okay, its a small change, but a change none the less.
If y'all wouldn't mind changing your sigs to use:
bliss.paulgraydon.co.uk instead of www.paulgraydon.co.uk
that would be grand :)
I did a post about a month back asking people to change to bliss.paulgraydon.co.uk instead of www.paulgraydon.co.uk as i'd moved the script over to a different box. No other changes are needed, replace the "www" part with "bliss"
