- 9 Apr 2012
iOS devices (and iPods before then), have always been much better than Android devices in terms of compatibility with car stereos, docks, etc. Plug in your iPhone to nearly any stereo with USB and you can browse the library on the stereo screen, all audio is output, etc.
Android doesn't have this and never has: the closest you can get is Bluetooth. It's only with Android Auto that it's slowly catching up. My question is why?
The potential for causing shorts is a huge design flaw - but if you design your audio equipment properly it shouldn't be an issue - i.e. there are op amps that can sustain an output short indefinitely. Impedance issues are always going to potentially happen around the digital to analog conversion point there isn't really a way around that - a well designed amp doesn't need impedance matching to sound good over a large range of devices though - with modern components even a fairly simple amp can handle 8-300ohms without issue if designed properly.
