Why has my performance dropped?
21 Feb 2011
Hi,
I used to get around 60fps-70fps on Bad Company 2 on pretty high settings, and suddenly that performance is now about 30-40fps. Does anyone have any idea what's going on?
- I recently changed PSU after my old one died, however it worked performance did not dip until a few days after
-AMD Phenom 955 X4 (Overclocked to 3.5Ghz)
-HD 5850 (Overclocked)
-4GB Kingston HyperX ram
I've tried down clocking everything, had no effect.
Thanks in advance
Not really.
Check that the power cables are fully secured to the graphics card.
You could try re-installing the drivers.
Check the GPU isn't getting too hot. Have a look and see if there's any accumulated dust which needs cleaning out.
