Hi all, so
I have an 8700k/2080ti/32gb 3000mhz ram setup which has recently begun stuttering not just in games but in the desktop too. I mainly play siege and cap the framerate at 240fps but I don't run freesync so my monitor is always at 240hz.
I get these pauses in game play every 30 or so seconds. Given the high fps I can run it must be losing A LOT before recovering. I don't lose signal its just a really horrible stutter.
I've deleted all recently added programmes and run the game/whatever with just the minimum of apps going so discord, uplay, the game and that's about it other than what W10 dictates. I also use the free version of Bitdefender.
Depending on what's going on in game with an uncapped frame rate I can easily max both gpu and cpu out (I play at 1440p) so to rule and kind of usage issue out I have tried running at a lower capped framerate but with no difference. I've removed OC's etc but to no avail. It had been running solidly for ages and now this?
I've run latency monitor whilst playing and it came up with this.
Any clues?
