- 3 Dec 2006
- Cornwall
I would'nt go for 64bit just yet, the reason being is that if all your softwear isnt running in 64bit then there is no point at all. The only softwear to run in 64bit is Windows XP x64 and Vista. The only real benifit to running the 64 bit version is you see about a 10% increase in performace with a 64bit OS.
However, drivers and support for 64bit are a long way off and some of your applications may not work with the 64bit version of Vista. I'm installing Vista 32bit first, then waiting for a year or two before 64bit takes off. It just hasnt taken off the way people thought it would. It seems that i have had no problems so far with 32bit support. I have been usiing a dual boot and i have had major problems with the 64x edtion of Vista due to drivers ect.
But i would finally say, lets wait until the 30th of Jan when most of the major companies will release drivers for both 64x and 32x Vista. Lets see what happens on that front.
