Why is Cinebench R11.5 crashing?
18 Apr 2011
UK
Hi guys,
I'm having a bit of a problem with Cinebench R11.5. The 32 bit render test runs absolutely fine, but for some reason every time I start the render test in 64 bit I'm getting this error (see link): http://i.imgur.com/bc9RoL0.jpg
I've looked at the "_BugReport.txt" file but it means absolutely nothing to me :(.
Does anyone know how I can fix this?
Edit - Here's the bug report: http://pastebin.com/c9gMQzF7
9/10 times it'll be due to an unstable system. If at stock speeds make sure memory is at correct timings and voltage. CineBench is an excellent overclook tool. It's usually the first thing to crash when on the edge of stability.
