Why is my 800 Mhz RAM only running at 533Mhz?
8 Oct 2006
I purchased some RAM from OcUK around a year ago that runs at 800Mhz, but at the time could only get it to run at 533Mhz in my BIOS - even though I increased the voltage and gave some tweaks as recommended on this forum.
I gave up at the time, but have now decided this is not acceptable.
It is DDR2 and 800Mhz, in a pentium 4 3.2Ghz PC.
What can I do? Let me know if you need any more information.
You don't need to. Your chip is running in sync (exactly the same speed) with you RAM. If you put your RAM faster than your CPU it will be waiting for the CPU - - -if you put your CPU faster than your RAM, your CPU will be hanging around for your RAM. In layman's terms, you are already at the 'sweet spot' for stock speed on your rig. ;)
Finally logged in again, and it has a "your system has recovered from a serious error' message - I seem to remember it did last time to.
Looks like it's more to do with my PC.. Any ideas?
And there is nothing I can do to change this?
As said below - you don't need to.
Best way to describe it.
Currently you're in your car (CPU) zipping down the motorway at 70mph.
There are 2 clear lanes in front of you, no traffic - it's midnight!
You now hit a patch of motorway with 4 clear lanes.
You were already going "flat out" with 2 lanes, adding 2 more won't make any difference.
Oops, that error message was for another post. Thanks for the analogy, glad to hear all is alright - PC certainly seems to be plenty quick (I use it as a Media centre now I have an XBOX 360).
