Why is my CPU Voltage changing?
4 Sep 2005
London
Hi all
My current CPU is an AMD Athlon XP 3200+ @ Stock (never been overclocked)
And my motherboard is an Abit KV-7.
The monitoring software that came with my motherboard is called ABIT EQ.
Basically i was just observing all the extra readings and noticed the VCore, CPU Voltage, was changing from 1.6v up to 1.75?
I doubt it makes much difference but i just wanted to know if this was normal? :confused:
Thanks
Yeah, it is normal for voltages to fluctuate a little.
If you are worried about it, you can get a cheap multimeter to find out how much exatly.
1.6 -> 1.75 is pretty drastic though, but I doubt it is actually rising that much, most likely an incorrect reading.
Hi,
no that's not normal? It normally fluctuate a little but not that much! ;)
Possible something to do with poor voltage regulators on the mobo, or maybe something to do with your PSU?
