Why is my RAM runnning at 669MHz
17 May 2009
Harrow, London
I bought some: OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel (OCZ3P13334GK).
I have set the correct voltage and frequency in the bios, yet it is still running at 669MHz, approximately half the speed it should be. Why is this?
Your running 1338mhz.
Double data rate - with cpu-z you need to double what it shows to give your speed :)
