- 15 Jan 2003
- London Baby!
My setup is as follows:
Main winxp pc connected to a zyxel prestige router via a cat cable.
Second winxp Pc connects to above router via a 54mbps belkin wirless card.
When i first set it up transferring files was about right speed for this connection.
Now a few days later its taking 50 mins to copy a 150meg file from the main pc to the wireless pc!!
No softwarree has been added nor has the configuration changed.
In the status on the belkin wirless software it shows up as being 11mbps connection, which is probably why i am getting a slow transfer rate. thing is i havent chanegd anything nor do i know what to do to gte it back to 54mbps.
Both PCs are in the same room and the siganl is showing around 87% strength .. any ideas?
cheers.
cheers.
