- 3 Mar 2009
Anyone else find it a bit annoying when you order a card which shows it as using the normal blow-it out the back cooling, to get instead one that dumps it in the case ?
It seems to happen pretty damn quickly, the initial stock uses it all, then all this wierd and random cooling stuff comes out a month or 2 later, and nearly everytime, from my experience, its crap ! Temps are almost always higher. Sure my case could use some better airflow, but then it wouldnt be as much an issue if the card arrived with cooling that dumped it out the case.
The only cards that appear to use the normal cooling are priced much higher too.
Why do they do this ? To bring prices down quickly ? Anyone else get annoyed by it too ?
