Why is Svchost.exe running so many times?
18 Oct 2002
Newcastle, England
Im having problems when shutting down or restarting my pc.. its down to an application but Im not sure which one. I have noticed though that the proccess Svchost.exe is running 7 times.. this cant be right?
http://img.photobucket.com/albums/v144/Jimbo68/iu.jpg
Can a mod resize the pic.. sorry. :(
If you cant resize it yourself, then just link it.
Otacon
many services run under the same svchost
remove whatever program you're using to monitor that, can be sure that its probably slowing your pc down!
just use taskmanager or process explorer from sysinternals
process explorer will tell you which services depend on which svchost file
start, run, services.msc
stop and disable services you don't need..
Jimbo said:
I had a look but really havent a clue what services to disable or enable.
i wouldn't bother. my windows is heavily tweaked and i still have 5 instances of svchost running.
you can read the ms blurb here....
http://support.microsoft.com/?kbid=314056
Stopping one of them made something go "ROFL" last time, so I just don't bother anymore.
I know I just treid to end all the svchost proccesses in task manager and it told my the system was re starting in 30 seconds lol.
Ok yeah I have done a scan and the system is clean but.. I have found the proccess that is causing all the headaches. It is DLLML.exe and it is from Creative Labs. It is crippling my restarts/shutdowns I'm having to wait 4 to 5 mins until the system will respond.
I found out this was causing it thanks to system mechanic, and some proccess elimanation.
Now how do I get rid of it? is it wise to disable it full time?
http://www.liutilities.com/products/wintaskspro/processlibrary/DLLML/
Edit:
I have Hijack this somewhere that would do the trick yes?
Bytw
i want it stopped. its not in services.msc, and its not in msconfig. it might be in the registry, but i hate having to fiddle with it unless i know 100% for sure that im getting rid of it properly
