I have been working on setting up a script to "move" files. Here is the code.
set the_folder to (choose folder)
tell application "Finder"
move selection to the_folder
end tell
Copy that into the Apple Script editor ( under Applications/AppleScript) and save it somewhere, I called it "QuickMove".
Then in the Apple Script Utility select to show the script menu in the Menu Bar.
Now select the Finder and in the script menu (on the top to the right if your using Leopard), select "Open Scripts Folder" > "Open Finder Scripts Folder".
Now copy your saved script in there.
Now when you click the script menu when using the Finder you will see your script ("QuickMove") at the bottom.
Ok now you can use it, select the files you want to move and click QuickMove in the scripts menu and select where you want them to go. Done done and done!
Hope that all makes sense, I find it very useful. Currently working on a keyboard shortcut for it but for some reason it doesn't work, maybe you guys can get it to work
