Why is this PNG fix not workin?
26 Jun 2003
North West
I want to use PNG's in IE and it aint doin the transparent stuff, im using the following method but its still putting a blue background on the PNG where it should be transparent.
Can anyone see whats wrong, or is there something else I need to change?
Code:
// HTML:
<head>
<!--[if lt IE 7]>
<script defer type="text/javascript" src="pngfix.js"></script>
<![endif]-->
</head>
// JavaScript Document - pngfix.js
var arVersion = navigator.appVersion.split("MSIE")
var version = parseFloat(arVersion[1])
if ((version >= 5.5) && (document.body.filters))
   for(var i=0; i<document.images.length; i++)
      var img = document.images[i]
      var imgName = img.src.toUpperCase()
      if (imgName.substring(imgName.length-3, imgName.length) == "PNG")
         var imgID = (img.id) ? "id='" + img.id + "' " : ""
         var imgClass = (img.className) ? "class='" + img.className + "' " : ""
         var imgTitle = (img.title) ? "title='" + img.title + "' " : "title='" + img.alt + "' "
         var imgStyle = "display:inline-block;" + img.style.cssText
         if (img.align == "left") imgStyle = "float:left;" + imgStyle
         if (img.align == "right") imgStyle = "float:right;" + imgStyle
         if (img.parentElement.href) imgStyle = "cursor:hand;" + imgStyle
         var strNewHTML = "<span " + imgID + imgClass + imgTitle
         + " style=\"" + "width:" + img.width + "px; height:" + img.height + "px;" + imgStyle + ";"
         + "filter:progid:DXImageTransform.Microsoft.AlphaImageLoader"
         + "(src=\'" + img.src + "\', sizingMethod='scale');\"></span>"
         img.outerHTML = strNewHTML
         i = i-1
I'm carp at code so can't say if it's right or wrong, but what i can say is that IE is carp at PNG files and as such doesn't display them with transparent BG
Edit : Ignore me it's a fix your doing to get them to work
Try this
Code:
<head>
<!--[if lt IE 7]>
<script language="JavaScript">
function correctPNG() // correctly handle PNG transparency in Win IE 5.5 & 6.
            i = i-1
window.attachEvent("onload", correctPNG);
</script>
<![endif]-->
</head>
All the JS should be in your head tags
Maybe worth reading this post if you haven already
If you've included the pngfix.js file--as you have by the end of the head--then you don't need to do any more. That code that you've pasted after the head is simply the contents of pngfix.js.
