Cold boot and it connects during the boot sequence to the point that you can open and use a connection for a few seconds, then before it has finished booting completely it will drop the connection and some random time later reconnect if you are lucky, often you have to go and tell it to even though it has been told to connect automatically. Same for resuming from standby/hibernate, it's almost enough to make me go back to XP on the laptop.
