- 17 Sep 2013
I built a pc myself a few months ago, I'll give you specs first
Mobo: Asus Z87 MAXIMUS VI FORMULA Intel Z87 http://www.overclockers.co.uk/showproduct.php?prodid=MB-562-AS&groupid=701&catid=5&subcat=2574
CPU Intel Core i7-4770K 3.50GHz (Haswell)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-471-IN&groupid=701&catid=6&subcat=567
PSU Super Flower Ladex, it's 1000w plat.
GPU Gigabyte Radeon R9 290 OC WindForce 4096MB GDDR5
http://www.overclockers.co.uk/showproduct.php?prodid=GX-133-GI&groupid=701&catid=56&subcat=1752
Ram is the Team GRoup extreme 8gb i think 2600mhz
If you need more specs ask.
So here is my problem. It worked fine all these months. Today I took it apart to put on my new compression fittings for my watercool loop and to spray my case. Took all the precautions I can and to my knowledge everything was done perfect.
I put everything back together, I used a jumper on the 24pin to help fill my loop first and when my loop and res was full I turned it all off and plugged it all back in and good to go. When I jumped it the pump and res came on with the fans. When I plugged it all back in the Motherboards start and reset lights came on and so did the Asus logo thing below the cpu but! that logo came on went off came back on went back off. It usually stays on.
I would press the power on button on my desktop. nothing, I try to use the mobo start, nothing. I tried the jump on the 24 pin again and the res/pump came on but not the fans this time.
I only know how to put pcs together, mostly, I'm still learning. But here are some things I'm speculating that could have ruined my system. All the power cables were hooked up to their relevant places when I jumped the 24 pin to fill my reservoir and loop. Could that have messed up my cpu or something?
Having a mild panic attack here so some suggestions to try in the morning would be appreciated please and thank you!
