Why isn't my IP working properly ?
Caporegime
8 Sep 2005
Norrbotten, Sweden.
im logging into a CDKEY site and it should show/record some details on IP and location.
Because this PC is miss behaving and not showing the info its causing grief buying stuff.
I asked a mate to log in from the UK to see if its me or them. It recorded his log in perfectly.
What the hell can be wrong with my router/PC to be blocking this info ?
If i go on whatsmyIP i get all the info perfectly and it says im not behind any proxies....
Help anyone ?
Im on Windows 7 - the router is a very old crappy netgear one that i have factory reset.
bgfsdrgbvsdfgbvrfsdwegvb
ta anyway. If you were looking at something
the .com of the site doesn't use cloud fire but all the .de . se etcs seem to use them so maybe thats why im getting that loop back ip ?
Whatever
its totaly screwed up my evening... My fault for being so cheap
