Been trying to play some CS lately and i've noticed how incredibly irratic my ping is no matter what time of day.
I've checked to make sure no1 is downloading then i pinged google, now i'm pretty sure its not supposed to be this irratic:
Then i did a trace route to google and it looks even worse!
The router ping is a constant 2ms over a 11b wireless network so no problems there as far as i can see and 3ms to any computer on the network.
Is this just a case of NTL being really poor or is there something more sinister at hand?
Connex is 1mb
Code:
Reply from 66.249.93.99: bytes=32 time=107ms TTL=245
Reply from 66.249.93.99: bytes=32 time=67ms TTL=244
Reply from 66.249.93.99: bytes=32 time=65ms TTL=245
Reply from 66.249.93.99: bytes=32 time=43ms TTL=245
Reply from 66.249.93.99: bytes=32 time=63ms TTL=244
Reply from 66.249.93.99: bytes=32 time=80ms TTL=245
Reply from 66.249.93.99: bytes=32 time=173ms TTL=244
Reply from 66.249.93.99: bytes=32 time=40ms TTL=245
Reply from 66.249.93.99: bytes=32 time=47ms TTL=244
Reply from 66.249.93.99: bytes=32 time=79ms TTL=245
Reply from 66.249.93.99: bytes=32 time=130ms TTL=244
Reply from 66.249.93.99: bytes=32 time=45ms TTL=244
Reply from 66.249.93.99: bytes=32 time=31ms TTL=245
Reply from 66.249.93.99: bytes=32 time=92ms TTL=244
Reply from 66.249.93.99: bytes=32 time=185ms TTL=245
Reply from 66.249.93.99: bytes=32 time=32ms TTL=244
Reply from 66.249.93.99: bytes=32 time=44ms TTL=245
Code:
1 88 ms 70 ms 263 ms 10.4.216.1
2 27 ms 19 ms 14 ms brtn-t2cam1-b-ge96.inet.ntl.com [80.3.66.173]
3 14 ms 34 ms 53 ms brtn-t2core-b-ge-wan62.inet.ntl.com [195.182.174
.37]
4 73 ms 50 ms 69 ms pop-bb-b-so-600-0.inet.ntl.com [62.253.188.237]
5 76 ms 175 ms 61 ms pop-bb-a-ge-000-0.inet.ntl.com [213.105.174.229]
6 81 ms 79 ms 54 ms nth-bb-b-so-010-0.inet.ntl.com [213.105.172.13]
7 30 ms 63 ms 44 ms tele-ic-1-as0-0.inet.ntl.com [62.253.184.2]
8 50 ms 90 ms 99 ms 212.250.14.66
9 59 ms 67 ms 78 ms 72.14.238.244
10 65 ms 55 ms 91 ms 216.239.43.120
11 72 ms 80 ms 134 ms 72.14.233.81
12 49 ms 95 ms 67 ms 66.249.94.54
13 247 ms 61 ms 118 ms 66.249.93.99
Connex is 1mb
