Why no DSR?
13 Oct 2011
Bristol
I have two 980s in SLI, and two monitors, an old Dell 3007WFP-HC, 30" 2560x1600, and a RoG Swift.
If I have SLI disabled, DSR shows up in nvidia control panel.
If I enable SLI, the DSR option vanishes.
If I leave SLI enabled, and disconnect the RoG Swift, DSR comes back.
If I leave the RoG Swift connected, but disable GSync, no DSR.
It seems like SLI, DSR, and RoG Swift, are a "choose any two" situation.
Any ideas? Anyone had similar?!
Officially SLI and DSR don't work together.
Some claim they have it working but I've got SLI 970's and a triple screen set up and DSR doesn't work for me.
DSR works with SLI as long as I don't have the RoG Swift connected.
I haven't actually tried disconnecting the Dell. Might see if that works.
Dar is working on my 970 sli setup with custom resolutions as well (72hz). Monitor is an aoc super widescreen.
I have heard some people say that depending on their native resolution (i.e 2560x1080 works, but not 2560x1440p) of their setup they can either get DSR or not.
I would think it would be fixed in future drivers...
I don't think DSR can do its thing if you're outputting to two separate monitors unless they are in clone mode.
This might be it, I'll try disconnecting the Dell.
Only one monitor?
Yes , I have another but usually just keep server connected to it most of time .
Tbh I prefer massively stupid frame rates over fidelity . Not being able to see those frames is a bummer but feeling them is enough for fluididity
I agree, since going to 1440p144 and Gsync I would never go back. I'd prefer a 1080p144 monitor to my old 1600p60 monitor, which I never thought I would say.
But there are plenty of games that I max out with 980 SLI and still hit silly frame rates.
L4D2 with DSR would be fun for example.
Yea , I mean if I fount a great deal on gsync with higher res I would upgrade , but having less than a year ago bought a IPS 1080p monitor at the wrong side of 200 I have a harder time justifying it to myself over actually hardware.
Will try downsampling a lot more with DSR to move the bottleneck from the CPU at this res I think tho
