Why not immerse the whole thing in liquid nitrogen?
1 Apr 2014
Aberdeen
I remember seeing pictures of whole PCs being immersed in oil to provide superior cooling, and I'm wondering if the same could be done with liquid nitrogen (or liquid argon or neon)? ISTM that this would remove any condensation problems. Or would it cause problems with the motherboard?
Stuff like regulators, etc. are only rated down to -25C operation, submerged in liquid nitrogen they'd quickly drop a good bit below -100C IIRC.
Just run your pcs from my living room, the wife leaves the door open and the draught would cut a man in two, plenty cool for the most overclocked pc.
Yeah the components would become mega-brittle. This is why you don't expose the CPU directly to LN2 and instead have it in a container mounted on top (IINM).
Now, submersion in oil or de-ionised water is another matter, and certainly possible.
Unless you are shooting for a WR LN2 is a bit of a waste of time anyhow - at that end of the scale huge temperature deltas are needed for increasingly smaller increases - for any other intents and purposes even a phase/peltier system regulated to stay above the dew point will get you close enough there will be no significant difference in real world performance.
Most chips on the motherboard have a cold way before -190c and aren't rated any lower than -10 or -25. So your keyboard and mouse wouldn't work. Also has well and skylake cold bug around -130c if its a really good one, so even the CPU would work. Memory doesn't like being too cold either.
t800 was arnie the 1000 was the liquid metal dude
Anywho, Even if everything freezing wasn't an issue LN2 boils off, so you'd need LN2 on tap to keep it filled, this isn't an issue for Mineral Oil.
I thought Arnie was T101?
Sorry going a bit of a derail here!
As others have explained, it's simply a case of good idea, just not practically/dangerous/expensive/mental :D
