I know this is a dumb question and there is obviously a reason why multi millions are spent on heat sinks but please help me along
The CPU heats up and passes that heat to the base of a cooler which transfers the heat via pipes ( losing heat on the way) to fins which loose their heat by having air blown across them
So in effect the CPU is loosing heat to air which is blown away, but why do we need the heat sink ? If the idea is to get the heat into the air and blow it away as fast as possible why not just have high powered fans blowing across the CPU perhaps with some sort of venting to funnel the air away ?
Is it that the base of a heatsink heats up faster than air thus is better at removing heat than air ? Could chiiled air not do as good a job ?
EDIt you may as well delete this crap post as it is obviously to do with conductivity rates..sorry !!
