I'd echo (pun intended) the above. To be fair though, once you have some Linux experience under your belt it really doesn't matter what distro you use - it's all GNU/Linux underneath. I flit between Arch, Fedora, openSUSE (or however they're spelling it this week
), Ubuntu, KaOS and myriad others on a daily basis. Apart from remembering to switch package manager syntax and that config files are in a slightly different place, it's just a case of po-tay-toe/po-tah-toe.
Cinnamon is more Windows-like than most, imho, and Fedora does a nice job with it. Rather than use Mint/Ubuntu I'd actually (highly) recommend
Pop_OS! by System76 - a US Linux laptop seller and distro maker. It is basically the latest Ubuntus (including the default upstream repos for updates/fixes) with speed and UI tweaks on top. They disable snapd by default, speed things up, add in some nice custom tools like battery monitoring and CPU frequency scaling, Do Not Disturb mode etc, and add a nice theme on top.
The advantage over Ubuntu proper is they package two versions - AMD/Intel and Nvidia. Both come with proper drivers installed which makes things much more plug and play for noobs, rather than messing around switching between FOSS/proprietary drivers and such to get things working. It also supports LUKS (drive encryption) right in their custom installer. You just install, update, add ubuntu-restricted-extras and you're away. Hardware video acceleration also works nicely in Chromium with intel-media-driver or i965, or the Radeon/Nvidia drivers - which is a nice bonus.
