so glad i whent sandybridge from x58 these boards and cpu`s are so much better
Because watercooling used to be a lot quieter than air cooling which isn't the case anymore.
Makes me laugh when people think watercooling is quieter erm how can 2 or 3 x 120mm fans on a rad be quieter than say 1x140mm fan on a heatsink ? It's more about extreme overclocks and cooling performance these days.
By watercooling you create a much larger surface area to cool with so you only need a fraction of the fan speed to do the same cooling. There is simply no way to have silent running with air coolers using smaller fans, heatsinks and maintain good overclocks all year round.
Bolting a water block to a high end GPU equals silence. Its not complicated mate.![]()
Also gets you laid.
Also gets you laid.
quote]
I thought my case was silent FT01, H50 with x2-Apaches, then x2 Vipers. Then a H20 loop is deadly quiet, the only thing l hear now is mt DVD-RW working.
.Surely that depends on if they are into water sports![]()
