why will my PC restart but not turn off ?
Caporegime
18 Oct 2002
West Yorks
every time i select turn off at windows it just reboots
i press the power button and it turns off alright, but every time i try and actually turn it off normally, it just restarts
only way to turn it off is to interupt it mid boot.
any ideas why my PC has suddenly started doing this ?
could try going to control panel\system properties\advanced\startup and recovery then in the system failure bit turning off automatically restart, that would bring up a blue screen should anything be wrong... I remember I had this on my old computer when I started using a pci vga card for a bit, I had to delete some random chipset driver...
What virus protection are you using, Norton by any chance? I think you'll find it's caused by a piece of spyware running in the background that won't shut down.
no norton
but im now getting an IRQ_NOT_LESS_OR_EQUAL
or similar message that causes it to restart instead of turning off. this doesnt happen in safe mode however
wierd...
In bios under power management, disable the option "Wake-up by ! PME# of PCI" "
Also check all the power saving and wake up options.
could be power supply not delivery 24A on the 12v rail .
the IRQ error sounds like a dodgy driver . Do you have HP printer software installled ?
m3csl2004 said:
dodgy driver issue sounds liek to me
your not using a creative product are you :D
yes ive even got a separate thread stating its causing my system to crash in the sound forum :rolleyes:
I haven't found the post in the sound forum and have went through a few pages, it wouldn't be something like onboard audio interfering with said creative product? (assuming it's a sound card)
Have you updated any drivers recently? Doesn't really make sense that it would just suddenly start doing it on it's own.
ive un-installed all creative drivers
run driver cleaner in safe mode
moved the sound card to a different IRQ slot
and re-installed
appears to have sorted both the crashing and the IRQ_NOT_LESS error
god bless "quality" creative products.
