- 29 Aug 2006
Right, I built a simple computer about 2 months ago and everything worked, all the hardware was compatoable and the OS installed and worked fine, i played a game on itand it worked fine. I then transported it 400 miles to my mates and set it up there and it didnt work. All the hardware was working but it was like windows had disappeared. I took out the optical drives and started it with the bare minimum and it appeared to work loading the windows 98 screen but then it went to a selection page, where you could select safe mode, normal etc. I tried both safe and normal etc. but it just said these files where missing ndis.vxd, ndis2sup.vxd, msmouse.vxd and system.drv and turned itself off and said plz reinstall windows. So i tried to reinstall windows but it wont let me, it says it cant access the hard drive. it looked like the hard drive had blown but when i went into its system on dos, it said that half the files where there.
WHat the hell is up with it??
PLZ HELP!!
Sanchez
PLZ HELP!!
Sanchez
