Why would a motherboard not include a VGA port? And how can I add one to my system?
frc
frc
21 Nov 2011
Many, many new monitors today are still connected by VGA, not just HDMI or something else. I have a gigabyte Z68AP-D3 which disappointingly has no VGA port. They saw fit to include a serial and parallel port, though! :confused:
But no VGA...
What is the reasoning behind this?
In any case, what's my best option? I don't really want to spend £120 on a different monitor (I only just got this one). Is it worth getting a cheap graphics card to act as an adaptor?
I'm assuming your graphics card has DVI? Dsub adapters should be a couple of quid at most.
I don't have a graphics card...
Apart from some USB and audio business on the front of the case, this is every way I can plug things in to my computer:
Then I stand by my unadulterated first post, yes, your best bet is a £20 gpx card.
Seems a shame to then cut off the i5's integrated graphics :/
From what I gather, until a certain graphics card price level I'll be downgrading essentially - paying extra to get worse graphics performance - compared to the integrated graphics :/
I could have just got a cheaper mobo that can't make use of them.
And it would have probably had a VGA port anyway, hah.
Any way I look at it this is a bizarre choice by Gigabyte not to include a VGA port...
And I'm surprised no one mentioned it ever - it's a popular board.
This. And from a quick search on the jungle they're only £5? However I'm not sure if the IGP will detect this and can correctly send analogue signals instead of digital.
I can't quite figure out yet if they work. Many vendors warn not to use them with a PC-->monitor situation.
In case anyone is as slow as me and finds themself in the same situation, I resolved this by using a HDMI<--->DVI cable (minimal cost) to make many more monitors available to me, not just those with HDMI-in.
Thanks for your help, everyone.
