Why would my Radio get hot?
Caporegime
8 Mar 2007
Surrey
Hi
This is either going to be a strange question, or im goign to be made to look stupid for asking something with a well known answer, but anyways...
I have an L reg 1.3 Ford Fiesta LX with the standard cassette radio in it. Recently, when driving for more than an hour or so, the front of the radio gets really hot, more specifically the area below the LCD screen and above the buttons, where the ford branding is.
Why could this be?
It has once got to the stage where it caused that hot plastic smell, but i then finished my journey and it hasnt happened since.
Cheers
Ive had radios get quite hot in the past, especially when being played loud, probably due to the internal amp.
The transistors they use in the amps belt out a lot of heat, depending on the circuit setup they can get hot even when idle. I expect because it's a bit older it's probably got dust on the heatsink and it's cooking up a bit.
that would be my bet. internal cooling is propbably blocked up with dust
