- 13 May 2024
- Antrim
Hi All,
I am having fibre installed from a broadband provider this week and they use the Eero Wi-Fi 6+ router/extender units.
Due to circumstances the fibre connection is being installed into my garage, not the main house.
The garage had a small Comms rack and the house has one also, approx 10 metres apart.
The plan is to put an eero 6+ unit in the garage Comms and one in the house Comms and they will like wirelessly through the common ‘TrueMesh’ platform.
However, if the link between both units is not strong enough, I have been told I might need a wi-fi bridge installed, (assume they are referring to a point to point link between the house and garage).
There is a clear line of sight between both locations.
( I am using an extender unit between locations at present on the old copper connection, approx 4mb only and have full bars in the garage location. Main BT router unit is in the house).
If the signal with the new units isn’t strong enough between the garage and the house and I need this bridge, I want to ensure:
1. I select the right type of bridge product and
2. I select a bridge product that is suitable to work in conjunction with the Eero TrueMesh system (and can support same).
Ideally when all completed I would like to see only one network to connect to within the property, regardless how many eero units I end up having.
Appreciate any help or guidance on the attached so that I get this right if I need to go down the bridge route?
Best
Simon
Best
Simon
