wich card
mrg
mrg
15 Apr 2010
hi all
i thinking of buy a 5870 to add to my xfx5970BE now what brand be the best for overclocking right now im thinking of xfx or asus plz gev me some advice on wich card and why
Are you using Eyefinity for multiple displays? Cause I don't think you really need more than a 5970 at the moment for gaming at a single monitor...
As for Crossfiring, the speed will follow the speed of the slowest GPU, so even if you can overclock the 5870 to high, it wouldn't make any difference if the GPU in your 5970 can't keep up. And since the 5870 GPUs in 5970 are downclocked, I think any 5870 would do...but ideally a brand that offer good warranty and RMA support.
Also, what the rest the spec of the rest of your PC?
thanx for the reply im thinking of ocing the 5970 any way so thats why i ask wich 5870 is good for ocing and you are right i dont need any more than one 5970 for most games but when i play crysis with avery thing set to high and 4xaa at 1080res at some parts of the map dosent feel very smoth thats why i think i need the 5870
i7 920 [email protected]
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel
Asus P6TD Deluxe Intel X58
xfx5970 BE
toughpower 1500w
window7 32bit
thermaltake xaser case
Swiftech wc kit
no you right mate 64bit os is good it can use all the 6gig ram but had some problems in the past with ati drivers and 64bit vista
xfx5970 BE
toughpower 1500w
window7 32bit
Swiftech wc kit
Ah for Crysis I can understand. I've seen a review on Custom PC that for Crysis at dx10, very high, 1920x1200, 4xAA, 16xAF, the 5970 frame rate is min 23fps, average 42fps.
But I honestly it's don't think it's worth investing another £300 just so you can get higher frame rate for ONE game. HD5970 in Battlefield Bad Company 2 in dx11, 1920x1200, 4xAA, 16xAF setting get like min 56fps, average 116fps...
Also games are slowly heading toward the direction increase use of tessellations, which is one area that the ATI5000 series is weak at. I say you should save your money for now, and move onto next gen graphic (if they are better) when they are out.
i need a crysis benchmark of some one with same gfx setup as mine
5970+5870 trifire both at stock speed
i just done a benchmark in crysis and this is what i got
1920x1080 veryhigh 4xaa
min=35
max=85
ave=65
dos this sound right
min=35
max=85
ave=65
If those figures are correct, then I don't really see the need of adding another 5870, as with min 35fps, you shouldn't really notice slow down (not enough to actually affect your gameplay anyway) unless you pay really close attention to it, which doesn't happen if you are more focus on the gaming itself...
Really in this day and age (especially with a modern system like yours AND 6GB Ram) there is no reason not to use a 64 bit OS.
hi guys
now i add a 5870 to my 5970 the only game that is working right is bad company2
in cod4 mw1 and mw2 only useing the 5970 not both cards looking at msi afterburner two gpu 99% and one gpu at 0% dos any one no why its doing this and to fix it
Just a question what happens to the ram in 32 bit Windows as it can only see ~ 3.25 gig of system ram and he will have a total 3 gig of GDDR ram on his GPU's if he grabs a 5870?
would that mean windows would only see 250MB of DDR ram?
In that case wouldn't the addition of another card actually slow down his gaming as he would be lacking ram?
AFAIK a 32bit OS will only see a max. of 4GB of memory, so considering a 5970 has 2GB of memory and a 5870 1GB of memory, the OS wil only be able to see 1GB of the available 6GB of installed system memory. It seems such a waste to have 5GB of RAM sitting there doing nothing.
