Finding a decent local chap easier said then done. I have an inherit distrust off all tradesmen!
Plus the stuff never fits 100%, always one corner with nothing off the shelves fits into.
Do you have a plan in mind? with measurements?
If your competent enough to order the stuff yourself, then http://www.diy-kitchens.com is totally kick ass. Decent carcasses, hinges and all round a lot better than the stuff you get from the big sheds. From experience. Worked out cheaper too.
Then just find a local decent cheapy to do the rest for you.
That's why finding a decent chippy helps. I had a 400mm unit that overlapped a bit of boxed out wall that was some pipework and there was also an awkwardly placed stop ****. The chippy hacked the back of the unit out and fitted it perfectly around the wall. Once the doors on, you can hardly tell, and it's a fairly useful cupboard.
Thanks for posting that, I have a kitchen to do soon, I think I will use them
As said, kitchens are fairly simple to knock together if you have moderate DIY skills.
Shaz]sigh[;24142132 said:Let me know how it goes, I've got a basket full of stuff waiting for some building work to be done. Works out £1k less than Howdens and that's with inframe stuff.
It wont be for a few months, the place it will be installed at is still going through legalities. :-/
