Wide viewing angel tft
6 Jan 2006
Newcastle upon Tyne
Hi, just wondering if anyone can recommend a wide view angel tft to mount on a wall so that people will be able to see it as clear as possible from slight angels.
Thanks, Mark
Hi,
Any premium S-IPS panels will do the job nicely, as panels based on this technology have excellent viewing angels. As you didn't specified the screen size and if the WS (wide screen) aspect is preferable, here are the options:
20"/20.1" WS
PHILIPS 200W6CS
NEC LCD20WGX2 (AS-IPS)
21"
NEC LCD2170NX
23" WS
Apple 23" Cinema HD
30" WS
Dell Ultrasharp 3007WFP
THanks for the reply. Forgot to put that we are looking for about 19/20 inch non widescreen. The reception area isnt that big so we dont want it to be over powering in there.
I see. When you say "slight angels", any idea about the required aspect of the viewing angles (45, 90, 180 ... or so) ? If you are half way to the 140-180 (or slightly lower) and response times are not so important, maybe 19" MVA or PVA panels may do the job and you could save some money, if this is for the reception and not your personal joy ;)
