Widescreen Backlight Bleeding
The 2005 was especially bad for backlight bleed. You'd be very unlucky to get something that bad again now, although perfect backlights are still rare. Backlight bleed isn't limited to widescreen btw, all the non-widescreen LCDs I've owned have had at least a little backlight bleed, and the 2 widescreens I've owned have had roughly the same amount.
Bleed is usually just down to the quality of the seal at the edges. It's just a build quality issue rather than anything to do with the shape of the screen. Like I said I've owned 2 widescreens and 3 non-widescreens and they've all had a similar amount of bleed (thankfully very little).
If anything a widescreen is easier to light. Take a 20" widescreen, that has a backlight top and bottom, and probably left and right too, and the distance form the centre of the screen to the nearest backlight is less than on a 5:4 screen. The squarer the screen the more distance the centre is from the nearest backlight.
Don't avoid buying a widescreen just because Dell had build quality issues with one model two years ago. If backlight bleed is a big issue for you then buy a top end screen like the NEC, or even an Eizo.
